Inventor Forum
Template Trouble
1 REPLY 1
edd_3
173 Views, 1 Reply
Template Trouble
Hi
Thanks in advance for any help.
I am trying to create a template file for a lockrod that needs a form in. For some reason the sketch of the form dissapears when the template is used but is still there when the file is opened directly?
1 REPLY 1
Yong.Jing
in reply to: edd_3
This should be as-design result. sketch view is unable to saved into the template re-use.
In order to view the sketch, you should copy all the sketch drawing into the titleblock, then insert them.  You could see the simply testing with your files.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
