Inventor Forum
Template Help! for Inventor IDW
29 REPLIES 29
Message 1 of 30
rnewcomb
1287 Views, 29 Replies
I have a IDW Template and want to change it so that when I bring in a IPT the lines of the drawing are in blue color
29 REPLIES 29
Message 2 of 30
rnewcomb
in reply to: rnewcomb
Message 3 of 30
chad38
Open your template file, then go to the manage tab and select "Styles Editor". Click the + symbol next to layers, and select "Visible" lines. Click the colored block under "appearance" and change it to the color you wish. Make sure and resave as a template.
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
Message 4 of 30
chad38
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 5 of 30
karthur1
1. Open the template file.
2. Manage > Styles Editor, expand the Layers Node.  Assuming you are talking about the "Visible Edges".... pick "Visible Edges" in the left pane. Now in the right pane, find the " Visible Edges" layer and change the color to what you want it to be. Click "Done" to exit the Styles Editor.
3. Now you have to write this to your Styles Library. On the Manage tab, Styles and Standards panel, click "Save".  If your library is read/write, this will write your changes to the library.
4. Save the template and exit.
Start  a new idw using this template and see if it works when you bring in a part.
Message 6 of 30
rnewcomb
in reply to: chad38
I did do that but it still isn't coming in blue
Message 7 of 30
chad38
You must save the style into the style library, otherwise it will replace the template file styles with the style from the library. So after you finish editing the style, you have to click to save the style into the style library.
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 8 of 30
rnewcomb
in reply to: karthur1
ok, mine says read only, how do I change that to read/ write
Message 9 of 30
chad38
Go into projects, in the bottom pane, right click on "Used Style Library" and select Read-Write.
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 10 of 30
rnewcomb
in reply to: chad38
Thank you for the help, I got it to say read/write but it still isn't coming in the color I want, any more ideas?
Message 11 of 30
chad38
Double check that you saved the styles to the style library. So if you reopen your template, go into the styles and if the color change to visible lines isn't showing as the color you wanted, change it to blue, then when you close the styles dialogue, save the styles to the style library, resave the template, and try again.
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 12 of 30
rnewcomb
in reply to: chad38
it is showing it set to blue in the template but not when I use the template and bring a part into it
Message 13 of 30
chad38
So when you bring in your view, it changes the styles settings back to black? But it was set to blue just before you brought in the view?
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 14 of 30
rnewcomb
in reply to: chad38
no, the template has it set to blue but when I open it as a new IDW using the template then before I bring in a view I checked it and it is black
Message 15 of 30
chad38
Sounds like you haven't saved the changes to the styles library. Make sure and do so, and tell it to replace the settings in the style library with the changes. So say "yes to all" when you are saving the settings.
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 16 of 30
karthur1
Then the idw file that you edited is not the one in your templates folder.  When you start a new file, it will show you where the template is being taken from.
This should be the one that you edit. If the one that you edited is not in this location, then use WIndows Explorer andcopy it to this location.
Kirk
Message 17 of 30
rnewcomb
in reply to: chad38
I could send you this template and you could check it, but It is changed inside the template but when I use the template then it is not saved to the color
What is your email?
Message 18 of 30
chad38
Just post the template as an attachment in a message on this board. That way everybody can have a look.
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 19 of 30
rnewcomb
in reply to: chad38
Message 20 of 30
chad38
I'm with KArthur on this, I think you don't have this file saved into your templates. Because it does have the style set as blue, and you say it's black when you start a new idw, something is amiss.
Also, if you had saved the style to the style library, I believe it would replace the color every time you started a new idw. So make sure you're saving it to the style library.
and select yes to all
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
