Inventor General
Valued Contributor
Message 1 of 30 (347 Views)
Accepted Solution
Template Help! for Inventor IDW
347 Views, 29 Replies
12-30-2013 08:18 AM
I have a IDW Template and want to change it so that when I bring in a IPT the lines of the drawing are in blue color
Valued Contributor
Message 2 of 30 (299 Views)
IDW template
12-30-2013 08:26 AM in reply to: rnewcomb
Distinguished Contributor
chad38
Message 3 of 30 (339 Views)
Re: Template Help! for Inventor IDW
12-30-2013 08:28 AM in reply to: rnewcomb
Open your template file, then go to the manage tab and select "Styles Editor". Click the + symbol next to layers, and select "Visible" lines. Click the colored block under "appearance" and change it to the color you wish. Make sure and resave as a template.
Cybertron PC
Intel Core i5-3470 CPU @ 3.20 GHz 3.60 GHz
16.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Inventor Professional 2014
Autocad Mechanical 2014
chad38
Message 4 of 30 (298 Views)
Re: IDW template
12-30-2013 08:30 AM in reply to: rnewcomb
Cybertron PC
16.0 GB RAM
*Expert Elite*
karthur1
Message 5 of 30 (335 Views)
12-30-2013 08:39 AM in reply to: rnewcomb
1. Open the template file.
2. Manage > Styles Editor, expand the Layers Node.  Assuming you are talking about the "Visible Edges".... pick "Visible Edges" in the left pane. Now in the right pane, find the " Visible Edges" layer and change the color to what you want it to be. Click "Done" to exit the Styles Editor.
3. Now you have to write this to your Styles Library. On the Manage tab, Styles and Standards panel, click "Save".  If your library is read/write, this will write your changes to the library.
4. Save the template and exit.
Start  a new idw using this template and see if it works when you bring in a part.
Valued Contributor
Message 6 of 30 (291 Views)
Re: IDW template
12-30-2013 08:40 AM in reply to: chad38
I did do that but it still isn't coming in blue
chad38
Message 7 of 30 (289 Views)
Re: IDW template
12-30-2013 08:42 AM in reply to: rnewcomb
You must save the style into the style library, otherwise it will replace the template file styles with the style from the library. So after you finish editing the style, you have to click to save the style into the style library.
Cybertron PC
16.0 GB RAM
Valued Contributor
Message 8 of 30 (324 Views)
12-30-2013 08:44 AM in reply to: karthur1
ok, mine says read only, how do I change that to read/ write
chad38
Message 9 of 30 (326 Views)
12-30-2013 08:48 AM in reply to: rnewcomb
Go into projects, in the bottom pane, right click on "Used Style Library" and select Read-Write.
Cybertron PC
16.0 GB RAM
Valued Contributor
Message 10 of 30 (312 Views)
12-30-2013 09:02 AM in reply to: chad38
Thank you for the help, I got it to say read/write but it still isn't coming in the color I want, any more ideas?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
