Inventor Forum
TempEmbed_(1).bmp in Inventor DWG when opened in AutoCAD
1 REPLY 1
BrettCaldeira
670 Views, 1 Reply
Hi There Guys
Hope all is well and someone is able to help.
I am having this issue quite frequently and am getting very frustrated. I have a few embedded images in my Inventor DWG Template and when I open the drawings up in AutoCAD all images dissapear and instead get replaced with TempEmbed_(1).bmp. Sometimes it works and there is nothing wrong, and other times I get the TempEmbed(1).bmp "replacement". Once this happens there is no way to recover the images, the only solution which works less then 10% of the time is to save the file as a different name, and then rename at a later stage.
We recently moved to 2013 (always run 1 year behind) and the issue above has become alot worse. Any non-migrated documents (2012) seem to work, but those migrated to 2013 do not.
I have searched the net and read a few posts, but none seem to have an actual solution, and know one knows if its an Inventor or AutoCAD problem.
Any help would be great.
Brett
1 REPLY 1
Found this discussion from January, and the solution... "there is no solution", find a work around and waste more time.
http://forums.autodesk.com/t5/DWG-TrueView/TempEmbed-bmp-Thumbnail-opposed-to-image/td-p/4294324
Please Autodesk, give me a fix...
