I am still relatively new to Inventor and have posted a model of a Tee using Inventor 2012.Could you view this model and see where i could improve or model it better.How would you make this model of a Tee?
Cheers
Ray
Only got Inventor 2009 here at work, but I'm guessing that by "Tee" you are referring to a Tee piece to be utilised in a pipe run?
If that's the case then I would create two intersecting rods, i.e. extruded circle shapes, and hollow out the resultant profile having selected remove faces for all three ends.
Still under this assumption, have you looked in content center for standard Tee pieces?
Nicely done.
Make sure the fillet on the Hex is correct. Often that is a revolved "chamfer" rather than a fillet.
