Inventor General
Valued Contributor
dpsmith85
Message 1 of 7 (730 Views)
Task Scheduler "unresolved references" error message
730 Views, 6 Replies
09-29-2011 01:36 PM
I am looking to batch convert my IDWs to AutoCad DWGs without having to go through and manually open each file and save as etc.  Right now I am using the export files task to do this.  I have saved an *.ini file with all the settings I want and successfully create the task.  After running the task it fails to convert all the files giving me an error message that says "File has unresolved references".  This shouldn't be the case though because the IDW's open and reference the part/assembly files fine.  Does anyone know how to fix this issue?
Autodesk Inventor Professional 2010 32bit edition SP3
Thanks for the help.
Product Support
VinodBalasubramanian
Message 2 of 7 (715 Views)
Re: Task Scheduler "unresolved references" error message
10-03-2011 03:06 AM in reply to: dpsmith85
The error "File has unresolved references" will appear when an assembly file can’t resolve components referenced in it. By default, task scheduler will skip these files. You can force task scheduler to migrate these files by using the options in the attached screenshot.
Vinod Balasubramanian
Valued Contributor
dpsmith85
Message 3 of 7 (710 Views)
10-03-2011 05:25 AM in reply to: VinodBalasubramanian
We may be running different versions, or maybe I'm confused about where you got that options box.  If I click on options in the Export files dialog box all I see is "export files options" which only chooses the *.ini file.  See the attached screenshot.  Am I looking in the wrong place?
Valued Contributor
dpsmith85
Message 4 of 7 (707 Views)
10-03-2011 05:41 AM in reply to: dpsmith85
I did find what you were refering to in the "update design" task.  I'm still a little confused though.  Am I supposed to run a task that updates the design of all the files and then run a separate task that converts idw to dwg?
Product Support
Message 5 of 7 (699 Views)
10-03-2011 05:19 PM in reply to: dpsmith85
Sorry for the confusion with the screenshot. Exactly, Since you have some unresolved references, Update your drawings with the same settings i have shown and then convert them to DWG. This might help to fix your problem.
Member
Message 6 of 7 (392 Views)
01-15-2013 12:32 PM in reply to: VinodBalasubramanian
Why does Task Scheduler (Design update & Export files) not support Vault projects ?
Active Member
Message 7 of 7 (64 Views)
02-13-2014 02:19 AM in reply to: mdumont
Its really wierd that you can open a file in Inventor and print/export it but when using Task Scheduler you cant due to "unresolved references". To use update you need to have the files checked out aswell if your using Vault. Why is it like this?!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
