Hi there
Today I decided to migrate all the files of one of my projects, and I realised that Task Scheduler would also save all my files and create PDFs of the .DWGs. I guess it saved PDFs of my DWGs because I have a rule making it do so after save.
I was happy.. that is, until I realised that it did a horrible job at creating the PDF files with missing lines and everything!
The odd thing, now, is that while the Task Scheduler did a horrible job, I can now open a drawing, just save it, and I have a perfect PDF file. It's the same Ilogic rule and everything!
If necessary you can find my PC specs in the bottom of the message, and I'll also paste my PDF rule and a few examples of Task Scheduler vs. opening and saving them manually.
If anyone has a fix for it, it'd be most appreciated! 🙂
'------start of iLogic------- oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension oRevNum = iProperties.Value("Project", "Revision Number") oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium 'Define the drawing Dim oDrawing As DrawingDocument oDrawing = ThisDoc.Document 'set PDF Options If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 600 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets End If If oRevNum = "" 'Set the PDF target file name oDataMedium.FileName = oPath & "\" & oFileName & ".pdf" Else 'Set the PDF target file name oDataMedium.FileName = oPath & "\" & oFileName & " Rev" & oRevNum & ".pdf" End If 'Publish document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) '------end of iLogic-------
Unfortunately due to company policy I cannot give you the full documents. I hope what I have provided is enough!
