Inventor General
Active Contributor
Message 1 of 4 (139 Views)
Task Scheduler 2013
139 Views, 3 Replies
12-12-2012 04:58 AM
Why doesn't task Scheduler give you an option to convert IDW to Autocad DWG?
It will only save IDW to Inventor DWG
Valued Mentor
Message 2 of 4 (133 Views)
Re: Task Scheduler 2013
12-12-2012 05:09 AM in reply to: smichels
You need to select 'Export Files' to convert from idw to dwg.
Regards
Martin
PDSU 2014 SP1.3
Windows 7 64bit SP1, Office 2007 Pro
Intel i7 980x, 24 Gb DDR3 RAM
Geforce 580GTX Graphics (Diver 327.23)
256GB SSD OS, 80GB SSD working folder
Space Pilot
Active Contributor
Message 3 of 4 (121 Views)
12-12-2012 06:18 AM in reply to: Martin_Goodland
It worked except exported dwg to zip file... Is there an option to export to dwg only.
Active Contributor
Message 4 of 4 (114 Views)
12-12-2012 06:40 AM in reply to: smichels
Martin,
I figured it out with your help.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
