Inventor General
Valued Contributor
Message 1 of 1 (34 Views)
Tapped hole conversion problem from MDT6
34 Views, 0 Replies
11-04-2002 05:23 PM
Hi.....I'm designing a new machine which has a few legacy parts from MDT6 (originally MDT5).....I've noticed a problem when converting MDT6 parts which have tapped holes....The part translates fine, but initially there is no standard specified in the hole dialog box.....To correct this you can simply select the standard you need - but it's a bit of a pain to select every tapped hole in every convered part.......A picture is worth a 1000 words, so see the file in the CF.....Unzip it, open it and create an idw........Then try to spot the thread lines on the 3 tapped holes........Cheers.....Sean
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
