I noticed that your Sketch1 is placed at the origin but not constrained. You might want to read this document -
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
I also noticed that your Ø.5 hole was not constrained and that you used a blind Extruded circle instead of a hole. The flat bottom hole will cost more to manufacture than if you had used the Hole command to create a drilled blind hole.
And finally, Sketch25 was unconstrained which made it difficult to determine your design intent - so I took a guess.
Pull down the red End of Part marker in the browser.
