Inventor Forum
Tapered Coil
11 REPLIES 11
Message 1 of 12
2672 Views, 11 Replies
Tapered Coil
Heyy there,
Im using Inventor 2013 and im trying to make a tapered coil but instead of creating it with a liner taper i want a curved taper. Is there a way to create this (prehaps using guide curves like loft feature?)
Im new to inventor but have been using solidworks for a while any help would be appreciated.
11 REPLIES 11
Message 2 of 12
Cadmanto
Edward,
Welcome to the forum.
Have you tried using the coil command under the Model tab?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 12
this is an old technique used on other software but works. 3D sketch a helix, 2D sketch a profile shape, surface sweep a line and project the intersect for your new path.
Hope this helps
Cheers
Mark
Inventor 2013
Message 4 of 12
yes, and i have even used the taper bit of that but the problem i have is that it creates a taper that comes out at an exact angle from the origin in a straight line. I need the taper to come out and taper along a curve.
another way of saying it would be that it tapers at 10deg which then gradually decreases to 5deg as the spiral increases.This would create a shape like a flower bud or light bulb.
Message 5 of 12
I will have a go at this later and see if i can get it to work 🙂 will report back
Message 6 of 12
JDMather
If you can't get it worked out - attach your attempt here.
Message 7 of 12
im struggling to create the surface sweep.
If you could make a video, or series of screen shots of the steps it would be brillient 🙂
Thanks Ed.
Message 8 of 12
Cadmanto
Do you have an image if what you are trying to model?
Best Regards,
Scott McFadden
Message 9 of 12
JDMather
Thanks Ed.
Attach something here. Anything you have attempted.
2d sketch
Line
Coil
Surface Output
Pitch and Height (or similar)
exit sketch
3d Sketch
intersection
Sweep
(see attached example)
Message 10 of 12
in reply to: JDMather
Ok heres what im trying to create and a how far a can get. Notice how the end tapers out? i want to create that but with much more of curved taper
Im able to create the surface revolve then create a revolved solid but i cant get any of the componants to line up, for example the helix is allways wonky and wont snap to an axis? Also dont understand "3D intersection"
Message 11 of 12
JDMather
See the file I attached above.
Never ever use the 3D sketch Helix - use Coil with line for surface instead.
Revolve open profile for revolved surface instead of solid.
Message 12 of 12
Got it!! Thanks guys 😛
