Hello
I probably got a retarded question.
I made a coil with taper.
Now I want to make a drawing with that taper, but I dont know how to do that.
Solved by MariaManuela. Go to Solution.
Retrieve the information from your part.
Attach your files here if you can't figure it out.
Thanks mate. That actually solved the problem.
BTW is this sulotion considered industry standard of doing a drawing with a tapered coil?
