Inventor General
vinzs78
Message 1 of 6 (688 Views)
Taper extrude problem
688 Views, 5 Replies
02-05-2012 03:09 AM
Hi Guys,
I have created a taper of 45deg after extruding it of 15mm. When i mesure the angle of the side it is saying "46.43 deg".
I don t understand that. Is there something that i am missing?
I have attached a screenshot and the file.
Thanks for the help (i am new 1week old new on inventor)
JDMather
Message 2 of 6 (681 Views)
Re: Taper extrude problem
02-05-2012 04:18 AM in reply to: vinzs78
Measures correctly here.
Have you installed Service Pack 1?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
jeanchile
Message 3 of 6 (669 Views)
02-05-2012 11:16 AM in reply to: vinzs78
I'm on my phone so I didn't open the ipt file but from the picture it looks like you are measuring the compound angle not the angle normal to the faces. If you select the proper faces I suspect you'll get the 45 you're after.
Inventor Professional 2013 (SP-2.3), Product Design Suite Ultimate
Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (331.81), Space Pilot Pro (3.16.1)
Laptop: Intel Core i7 3.9GHz, 16.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTX 780 (331.81), SpaceNavigator (3.17.7)
blair
Message 4 of 6 (653 Views)
02-05-2012 03:28 PM in reply to: jeanchile
You are indeed measuring the compond angle. If you mease as posted the face of the chamfer with your top or bottom face you will indeed get 45 degrees.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
vinzs78
Message 5 of 6 (608 Views)
02-12-2012 10:04 PM in reply to: blair
Hi guys,
thanks for your replies. I still cannot resolve my issue.
Blair, are you meaning that if i extrude of 15mm and then set the taper at 45deg, the "compond angle" (= the one i am mesuring in the jpg) isn t going to be of 45deg.
If this is true, what should i do to extrude a rectangle of 15mm and then have the 3 compond angles at 45deg ?
thanks for your help guys, i have spend a few hours trying to fix this...
blair
Message 6 of 6 (603 Views)
02-12-2012 10:45 PM in reply to: vinzs78
First, the Chamfer/Taper angle is the face of the sides, not the corner angle.
Second, you are measuring the corner to the base edge.
Try measuring the corner Edge to either the top face or the bottom face.
And really what are you trying to accomplish (what do you want), Chamfer/Loft is a face measurement to a face.
Do you want the sides to be 45 degrees. The measurement you are making in your picture is a most unusual way to measure.
Win7-64
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
