oops, yes I meant fillets... sorry
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"AUGUST PANNING"
wrote in message
news:3E63A5BB8523F132641AC631330F099D@in.WebX.maYIadrTaRb...
> You do mean to use fillets and not chamfers correct in this test?
> I too wish you could check the show tangent edges option before creating a
> view. I've been doing quite a bit of piping as of late and having the
views
> default to show tangent edges would be nice. Also, show tangents is the
> default in shaded views. Don't think there is anyway around this.
> As far as Inventor not recognizing you changed view format is due to the
> fact the view style update doesn't occur till you click ok. It didn't give
> me the option to change it 50% of the time, it never gave the option at
all
> till I clicked ok then went in and reedited the view.
> Seems as though it would be better if the view updated the instant you
pick
> the view style change before you click ok to finish the view edit.
> Veiw editing could use a little streamlining in the next SP *crosses
> fingers*
