I have a part where I have placed a number of table driven iFeatures. These features generate parameters in the model that I can see in the parameter table. I am trying to find a way to have these iFeature parameters show up in the hole table in my drawing.
By 'exporting' the parameters, I have been able to get the values to show in notes and drawing view labels but I can't find a way to add them as a 'New Property' in my hole table.
Ideas and work arounds are welcome.
Brian,
Is there any way that you can post your part for me to take a look at?
If not publicly, then I can send you an email and have you include it as a reply.
Will this work for you?
Sure,
Here's my test part and drawing. You can see in the hole table that I tried a number of different properties to try and bring in the exported parameters.
Brian
Brimal,
I took a look at your files and you will need you build your custom Drill Schedule with iLogic.
I am not an iLogic expert by I have seen similar things done with illogic by others.
I hope that this helps.
Maybe someone will be kind and provide your with some example code.
