I am currently having a lot of difficulty trying to constrain an assembly.
The scenario is this:
I have a sleeve which I am trying to put on a shaft.The hole is quite large in the sleeve. On the side of the sleeve (at 90 degrees to the big hole, is a smaller hole which which goes all the way thorough the sleeve. This hole takes an L shaped handle in order to turn the shaft once it is all assembled (like the handle on a vice). I am trying to insert this L shape into the small hole using INSERT, but the large hole keeps getting selected. I have done the select other button(green button with little left and right arrows) but no luck, it is selecting the big hole as if it dominates the component.
Please tell me:
I am really open to suggestions as this is the most difficult part for me in Inventor.
David.
You can't post attachments via e-mail. You need to follow the link to come back to the forums and reply on the actual webpage in order to attach files.
