I have never used the addin, but this is taken from a post in the Customization NG
Basically it sounds like after registering the program you need to add a custom property
called TimeStamp and reference it into your titleblock or wherever you want it to show
It is written as an Add-in. When a Save or Save Copy As is invoked it
gets the system date and time and feeds it in to a Custom Property, name
TimeStamp, that I have added to my title block and it gets placed on the
drawing.
To use this program you need to add a Custom Property to your title
block and then install the Add-in. I've written a simple batch file to
install it and you will need to text edit the batch file to point to
where you've unzipped the files.
Included files:
Install_TimeStamp.bat - uses Timestamp.dll and Timestamp.reg to load and
register the app.
TimeStamp.dll
TimeStamp.reg
TimeStamp_package.zip -- contains source and other necessary files for
editing.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Chris" wrote in message
news:BBFDA1DCDEB50AB2B8E95F6BB3D85384@in.WebX.maYIadrTaRb...
> Could someone please give me some help. I want to know how to run the
> timestamp (from CBLISS).
> IV 7 sp1
> Dell Workstation PWS 360
> Windows XP Pro sp1
> Pentium 4 - 3.0 GHz & 1.5GB of RAM
> NVIDIA Quadro FX 1000 - 6.14.01.4371
> 18 x 20 dual UltraSharp Monitors
