Inventor Forum
THREAD DIRECTION IN IDW HOLE NOTE
2 REPLIES 2
BLHDrafting
1034 Views, 2 Replies
Aside from manually adding RH or LH to a hole note leader, anybody know of a way of getting the HOLE Direction (left hand or right hand) into the leader note?
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
2 REPLIES 2
blair
in reply to: BLHDrafting
The one way would be to edit the "Threads.xls" file and edit and add/insert rows for the RH and LH threads. Inventor pulls the data from this file, so adding the direction to the designation column will be read into the feature and then the drawing.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
BLHDrafting
in reply to: blair
Thanks Blair.
Editing the Thread.xls file works, but is at best a work around. After the editing you then need to select the thread size with the LH additiona nd still select the Left hand direction radio button.
I'll add this to the IdeaStation as a feature request. Thanks again.
Brendan Henderson
