Diane,
Your method works for ONE TIME only. Then everytime I add a text or leader
text, I have to select the text style again and again. In my .idw template,
I have 4 diff. text styles for B (.125), C (.156),D(.200) and E(.25) sheets.
.200 is a default one, then when I have a drawing in B-size, I have the
change the text size to .125 everytime I add a text. Dave seems to have a
trick for this problem.
"pick the style you want to be the default, edit one of the values,
save, then edit it back to the way you want it"
"Diane Hawes (Autodesk, Inc.)" wrote in message
news:F6B12C6D8E74807E22BD4E5B8568B91D@in.WebX.maYIadrTaRb...
> Chris,
> There are two ways you can set the "active" text style for Text and Leader
> Text objects. This is also true for text created in a drawing sketch
called
> Text and Property Field.
> 1. When you start the command, you can select the text style you want for
> your Text or Leader Text object by selecting it in the Styles combo box on
> the tool bar.
> 2. The act of creating a new text style or editing an existing text style
> makes it the "active" text style for Text and Leader Text objects.
> The Sheet Text Style is used by objects that do not have a text style.
For
> example, Surface Texture Symbol, Feature Control Frame, etc. Dimension
> Styles, which also have a Text Style, are only used by dimension objects,
> such as, any of the General Dimensions, Baseline, and both Ordinate
> Dimensions objects, etc. There are other objects that have Text Styles.
> You can find them by looking in the various tabs on the Drafting Standards
> dialog.
> Hope this helps...
> Regards,
> Diane Hawes
> Autodesk, Inc.
