"MechMan" <mechman> wrote in messageI
href="news:f14094a.2@WebX.maYIadrTaRb">news:f14094a.2@WebX.maYIadrTaRb...
agree. You should have gotten a system with WinXP Pro instead of Win2k. XP Pro
supports HT.
AFAIK Win2k supports 4+ GB RAM.
Did the computer builder use quality RAM (Corsair, Kingston,
etc...)?
Is Win2k up-to-date with SP3?
I think when you use dual CPU's the top performance of each individual CPU
drops a little. So in essence each 2.8Ghz CPU may run an app a bit slower than
a single 2.8Ghz CPU. I'm not positive about that though.
MechMan
Hey MechMan what does AFAIK mean? you guys and
your abbreviations<G>
Our tech talked to two Microsoft support
guys and one said W2K does support 4GB ram and one guy said it only supports
2GB ram! All I know is I have (4) 1GB sticks of good quality ram and the OS is
only seeing 2.8 GB total ram.
Pro supports HT.
etc...)?
CPU drops a little. So in essence each 2.8Ghz CPU may run an app a bit
slower than a single 2.8Ghz CPU. I'm not positive about that though.
MechMan
Check your BIOS settings to see if it's set up to recognize RAM in all 4
slots.
Have you run a real test between your old and new system to make sure it's
not just your perception of speed?
MechMan
"rllthomas" <Just
href="mailto:rllthomas@attbi.com">rllthomas@attbi.com> wrote in message
href="news:f14094a.3@WebX.maYIadrTaRb">news:f14094a.3@WebX.maYIadrTaRb...
my opinion:
Your old system had an Athlon processor which I have heard
has a better FPU. I don't know how much Inventor relies on this but it could
be a possible consideration. You went from an intel equivalent of 2GHz to
2.8GHz which should provide a performance increase of about 25% on
computational intensive tasks like large arrays and filleted and drafted
parts. Your second processor, well that has been proven to actually decrease
performance some. That was the case when I did some benchmarking with Cosmos
Designstar. It wasn't a big difference but it was measurable.
As for
your ram, a single process can only access 2GB in a 32bit system so if all you
run is Inventor and the OS you need 2GB plus your overhead. Perhaps 2.5 GB but
then again since a lot of the overhead etc. is cached you just aren't gaining
much with more than 2GB ram.
So you should notice an increase on
complex parts, and in large drawings because of the processor. If your weren't
using more than 1.5GB of ram before then the 4GB is giving you no
benefit.
Rich Thomas
"Albert Allen" <
href="mailto:albert@sno-cat.com">albert@sno-cat.com> wrote in message
href="news:D02CC7FA608A161326330C954CC33620@in.WebX.maYIadrTaRb">news:D02CC7FA608A161326330C954CC......
Hey Mech, the bios is setup for 4GB ram and the
ram test at bootup sees 4GB but the OS does not.
When we disabled hyperthreading in the
bios the performance definitely got better and is now better than my
old machine but not nearly as good as it should be.
It is hard to find benchmarking programs for
these processors, do you know of any?
slots.
it's not just your perception of speed?
MechMan
