Inventor Forum
Synchronize Balloon with Part List
5 REPLIES 5
abilabib
783 Views, 5 Replies
I have litte problem for synchronize ballonwith part list where some times I put single component to main assy for create detail drawing. The problem is ballon from single component must change manually for synchrone with Part List. If number changed in part list sometimes I forgot for change ballon. So it's become miss match between ballon and part list.
Could someone explain me how to make this become synchron.
Please see attached file.
Abi Labib
5 REPLIES 5
MariaManuela
in reply to: abilabib
What Inventor version? 2012?
You know the BOM (Bill Of Materials)? You work with it?
if you change item numbers in BOM you get what you need.
Asidek Consultant Specialist
www.asidek.es
Hi abilabib,
Paul Munford covers one solution at this link:
http://cadsetterout.com/inventor-tutorials/autodesk-inventor-creating-coordinated-bom-for-large-asse...
I hope this helps.
Curtis
Hi Curtis,
Thanks for your link. It's very helpfully Smiley Happy.
Abi Labib
abilabib
I had trying the methode follow your link but if I use Bom view structure (legacy) this methode isn't not work. Can you advice another methode.
gnk2179
I have better solution for this one
Just try attached macro
procedure is
Give all balloon to assembly
Draw detail view from the ipt files then balllon will come as 1
open the maco file
then go to ur drawing
tools -macros, runt the macro
select the sheet
After that u will noticed that Balloon Synchronize
Ganesh Kumbhar
