Inventor General
Valued Contributor
abilabib
Message 1 of 6 (395 Views)
Synchronize Balloon with Part List
395 Views, 5 Replies
01-02-2012 07:52 PM
I have litte problem for synchronize ballonwith part list where some times I put single component to main assy for create detail drawing. The problem is ballon from single component must change manually for synchrone with Part List. If number changed in part list sometimes I forgot for change ballon. So it's become miss match between ballon and part list.
Could someone explain me how to make this become synchron.
Please see attached file.
Abi Labib
MariaManuela
Message 2 of 6 (364 Views)
Re: Synchronize Balloon with Part List
01-03-2012 08:13 AM in reply to: abilabib
What Inventor version? 2012?
You know the BOM (Bill Of Materials)? You work with it?
if you change item numbers in BOM you get what you need.
Maria Manuela Pinho
Application Specialist
Cadtech / Asidek - Autodesk Gold Partner
Autodesk Inventor Professional 2015 | Lenovo W520
Curtis_Waguespack
Message 3 of 6 (356 Views)
01-03-2012 08:25 AM in reply to: abilabib
Hi abilabib,
Paul Munford covers one solution at this link:
http://cadsetterout.com/inventor-tutorials/autodesk-inventor-creating-coordinated-bom-for-large-asse...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
abilabib
Message 4 of 6 (339 Views)
01-03-2012 02:42 PM in reply to: Curtis_Waguespack
Hi Curtis,
Thanks for your link. It's very helpfully :smileyhappy:.
Abi Labib
Valued Contributor
abilabib
Message 5 of 6 (318 Views)
01-03-2012 10:40 PM in reply to: abilabib
I had trying the methode follow your link but if I use Bom view structure (legacy) this methode isn't not work. Can you advice another methode.
New Member
gnk2179
Message 6 of 6 (223 Views)
10-03-2012 05:43 AM in reply to: abilabib
I have better solution for this one
Just try attached macro
procedure is
Give all balloon to assembly
Draw detail view from the ipt files then balllon will come as 1
open the maco file
then go to ur drawing
tools -macros, runt the macro
select the sheet
After that u will noticed that Balloon Synchronize
Ganesh Kumbhar
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
