Inventor General
Message 1 of 6 (497 Views)
Symmetrical dimples
497 Views, 5 Replies
02-27-2013 04:04 AM
Hi
I want to make symmetric surface i.e. golf ball with dimples. I found that I can do them by using revolve cut but how can I set them symmetrically on whole spherical surface
Cheers PiotrekL
Message 2 of 6 (467 Views)
Re: Symmetrical dimples
02-27-2013 08:24 AM in reply to: PiotrekL1
Anyone can help?
Valued Mentor
mpatchus
Message 3 of 6 (463 Views)
02-27-2013 08:37 AM in reply to: PiotrekL1
Accurately modeling a golf ball has always been a good challenge.
I used this many times in my classes.
It can be done, if you think outside your comfort zone.
Traditional patterns will not work accurately.
I have one on my box at home.  If I can remember I'll upload it tonight.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Curtis_Waguespack
Message 4 of 6 (461 Views)
02-27-2013 08:43 AM in reply to: PiotrekL1
Hi Petitioner,
Here is an example modeled by Inventor expert Loren Jahraus:
http://forums.autodesk.com/autodesk/attachments/autodesk/121/3658/1/GolfBall.zip
Note that you'll need to click and drag on the End Of Part marker to expose the features in the tree.
Keep in mind that this is just one example that represents a golf ball, but the actual pattern on a typical golf ball is a bit more involved. There are probably other techniques that can be used as well, but this should serve as a good general example.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 5 of 6 (430 Views)
02-27-2013 11:44 AM in reply to: PiotrekL1
Hi
Thank you very much for the response. I will have a look at the file now
I am quite new to Inventor.
BTW I know this is off top but I applied for the Inventor Training so I hope I will improve my skills which are now elementary. I'm gonna design H Darrieus wind turbine in Inventor for my engineers dissertation. Wish me luck:-)
Probably I will drop some posts during this period
Cheers
PiotrekL
Message 6 of 6 (413 Views)
02-27-2013 07:39 PM in reply to: PiotrekL1
See this
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
and this
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
