Inventor Forum
Symmetrical dimples
5 REPLIES 5
PiotrekL1
2685 Views, 5 Replies
Symmetrical dimples
Hi
I want to make symmetric surface i.e. golf ball with dimples. I found that I can do them by using revolve cut but how can I set them symmetrically on whole spherical surface
Cheers PiotrekL
5 REPLIES 5
PiotrekL1
in reply to: PiotrekL1
Anyone can help?
mpatchus
Accurately modeling a golf ball has always been a good challenge.
I used this many times in my classes.
It can be done, if you think outside your comfort zone.
Traditional patterns will not work accurately.
I have one on my box at home.  If I can remember I'll upload it tonight.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Hi Petitioner,
Here is an example modeled by Inventor expert Loren Jahraus:
http://forums.autodesk.com/autodesk/attachments/autodesk/121/3658/1/GolfBall.zip
Note that you'll need to click and drag on the End Of Part marker to expose the features in the tree.
Keep in mind that this is just one example that represents a golf ball, but the actual pattern on a typical golf ball is a bit more involved. There are probably other techniques that can be used as well, but this should serve as a good general example.
I hope this helps.
Curtis
PiotrekL1
Hi
Thank you very much for the response. I will have a look at the file now
I am quite new to Inventor.
BTW I know this is off top but I applied for the Inventor Training so I hope I will improve my skills which are now elementary. I'm gonna design H Darrieus wind turbine in Inventor for my engineers dissertation. Wish me luck:-)
Probably I will drop some posts during this period
Cheers
PiotrekL
JDMather
See this
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
and this
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
