Inventor General
RobJV
Message 1 of 11 (537 Views)
Accepted Solution
Sweep without twist
537 Views, 10 Replies
09-30-2013 04:24 PM
I have a sweep using a 3D sketch.  The sweep will form "rails" for a ball run.  I have attached my part and picture.  I assume I have to use a guide surface to prevent the rails from twisting as shown.  Ideally I would like them to end as shown in the sketch in the lower right corner.  Any help in accomplishing this would be great.
If somebody has a better method that would be great too.
(The run is not exact nor finished and the there are extra unconstrained sketches in the part file.)
Rob
Inv 2013 Pro
Distinguished Contributor
Mark.Downes
Message 2 of 11 (476 Views)
Re: Sweep without twist
10-01-2013 01:39 AM in reply to: RobJV
Hi RobJV
I had a quick go at this (made up part), I used a 2D sweeped profile as a guide surface for the
main sweep.
Hope this helps
Cheers
Mark
Inventor 2013
Valued Mentor
mpatchus
Message 3 of 11 (458 Views)
10-01-2013 03:56 AM in reply to: RobJV
I personally would make each rail its own part, and make this whole thing an assembly.
In the real world, this would not be a single part.
I've always told my students that they can never go wrong by mimicing the real world.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
RobJV
Message 4 of 11 (425 Views)
10-01-2013 09:48 AM in reply to: Mark.Downes
Thanks for providing the sample.  I will look over and post if I have any questions.
Rob
RobJV
Message 5 of 11 (422 Views)
10-01-2013 09:51 AM in reply to: mpatchus
Yes, of course I will be making these as separate parts.  (This can still be done as a single part and broken up.)
RobJV
Message 6 of 11 (414 Views)
10-01-2013 10:29 AM in reply to: Mark.Downes
Thanks - your sample helped a lot!
RobJV
Message 7 of 11 (376 Views)
10-01-2013 05:06 PM in reply to: Mark.Downes
I went through and created my own set of ball rails.  I only noticed one mistake in your sample that may help others.  Work Plane 2 should be built off of the top line of sketch 2 and not the angled line.  This will ensure that the track cannot intersect itself.  Thanks again for leading me down the right path!
Mark.Downes
Message 8 of 11 (358 Views)
10-02-2013 12:40 AM in reply to: RobJV
Morning Rob,
My Bad that one (well spotted), here is an updated model. Glad it helped.
Cheers
Mark
Inventor 2013
Employee
GlennChun
Message 9 of 11 (318 Views)
10-02-2013 03:16 PM in reply to: Mark.Downes
Hi Mark, Rob,
The sweep body in rail-02.ipt does not correctly pass the required cross-sectional profiles.  See rail-02-check-cross-sections.ipt.
I recommend to use the pull-direction sweep (aka plane normal sweep) in this case.   Here's how I created the attached rail-03.ipt:  Open rail-02.ipt. Make the XY Plane visible. Edit the Sweep1. Press the Guide Surface button. While pressing the Ctrl key, select the existing selection of the guide surface.  Now the arrow button should turn red because the guide surface selection has been deleted.  Click the XY Plane.  Hit OK.  This will create a sweep body whose cross-sectional profile orientations are controlled by the Z-Axis direction.
In rail-03-check-cross-sections.ipt, you can see the sweep body correctly pass the required cross-sectional profiles.
For the pull-direction sweep, the path doesn't have to lie on the plane or planar face used as a guide surface.  Inventor passes the normal vector of the plane to ASM, not the plane or planar face.  Only the vector information is important for the pull-direction sweep.  When the guide surface is curved, the path should lie on the surface which is passed to ASM.
Hope this helps,
Glenn
ASM Development
Autodesk T-Splines Component Development
Mark.Downes
Message 10 of 11 (304 Views)
10-03-2013 12:54 AM in reply to: GlennChun
Morning Glenn,
I followed your example using the XY plane, I also deleted the un-used guide surface. That’s a great example, I will be printing this to file away in my book of “did you knows Tip-bit’s”
Cheers
Mark
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
