Inventor Forum
Sweep with Guide?
10 REPLIES 10
Message 1 of 11
RKCADSERV
814 Views, 10 Replies
Sweep with Guide?
Hi All,
I'm after some advice on which is the best way to model the attached drawing. I've tried using a sweep along a guide but can't get the desired result!
Does anyone have any ideas (or example) thay might like to share?
Thanks for any help in advance.
Rob K
10 REPLIES 10
Message 2 of 11
JDMather
in reply to: RKCADSERV
Attach the ipt file here of your attempt.
Search here on wavy washer.  (this problem has been covered here many times in the past.
Message 3 of 11
RKCADSERV
in reply to: JDMather
Many thanks for your reply. I have looked up the wave washer discussion and I can now complete the model I was looking at.
Rob K
Message 4 of 11
rhasell
Hi
Just saw this this, so I thought I would give it a try. (Using the sweep)
See attached.
Reg
2024.2
Please Accept as a solution / Kudos
Message 5 of 11
RKCADSERV
in reply to: rhasell
 Hi rhasell,
Thanks for your feedback. I like the way you have constructed the part. One more silly question! I understand the construction but how have you actually put the 3D curve in there (what commands)?
I'll have a play around to see if I can get there by myself but if you'd wanna share then that would be great.
Thanks for your help.
Rob K
Message 6 of 11
JDMather
Looks like a spline created in 3D sketch.
I might have simply done a 3D intersection - no extra workplanes required.
3 2d sketches rather than 4
see attached.
Message 7 of 11
JDMather
or a solution with only 2 2d sketches rather than 4.
Message 8 of 11
rhasell
Hi
Create the base sketch with req OD of 25mm with 2 points top and bottom.
Created a point for a workplane @ 20mm radius.
Created the workplane at above point.
Create sketch on workplane, create 2 points, left and right.
Create 3D sketch, create a spline between the 4 points, changed the spline fit method to "Minimum energy"
Create the sweep profile sketch.
Sweep the part.
I had a look ad JD methods, all good, just different ways of doing it.
Reg
2024.2
Message 9 of 11
JDMather
@rhasell wrote:
Hi
The 3D curve is different.
Message 10 of 11
rhasell
Thats what I love about Inventor as well as the forums, there is often more than one way to model a part, and when more than one person contributes, that's how we learn (Or at least I have) the different aspects and features of the software.
I did not even consider a 3d intersection, and will store that in the memory banks for future use.
Reg
2024.2
Message 11 of 11
JDMather
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
