Inventor General
Message 1 of 11 (312 Views)
Sweep with Guide?
312 Views, 10 Replies
10-07-2012 01:52 AM
Hi All,
I'm after some advice on which is the best way to model the attached drawing. I've tried using a sweep along a guide but can't get the desired result!
Does anyone have any ideas (or example) thay might like to share?
Thanks for any help in advance.
Rob K
Message 2 of 11 (297 Views)
Re: Sweep with Guide?
10-07-2012 04:49 AM in reply to: bobbie.k
Attach the ipt file here of your attempt.
Search here on wavy washer.  (this problem has been covered here many times in the past.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 3 of 11 (279 Views)
10-07-2012 07:30 AM in reply to: JDMather
Many thanks for your reply. I have looked up the wave washer discussion and I can now complete the model I was looking at.
Rob K
Valued Mentor
rhasell
Message 4 of 11 (252 Views)
10-07-2012 08:19 PM in reply to: bobbie.k
Hi
Just saw this this, so I thought I would give it a try. (Using the sweep)
See attached.
Reg
Autodesk Product Design Suite Premium 2014 SP1-Update 2 Build 222
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please accept as a solution if it fixes your problem.
Message 5 of 11 (205 Views)
10-08-2012 09:42 AM in reply to: rhasell
 Hi rhasell,
Thanks for your feedback. I like the way you have constructed the part. One more silly question! I understand the construction but how have you actually put the 3D curve in there (what commands)?
I'll have a play around to see if I can get there by myself but if you'd wanna share then that would be great.
Thanks for your help.
Rob K
Message 6 of 11 (195 Views)
10-08-2012 10:20 AM in reply to: bobbie.k
Looks like a spline created in 3D sketch.
I might have simply done a 3D intersection - no extra workplanes required.
3 2d sketches rather than 4
see attached.
Message 7 of 11 (194 Views)
10-08-2012 10:23 AM in reply to: JDMather
or a solution with only 2 2d sketches rather than 4.
Valued Mentor
rhasell
Message 8 of 11 (157 Views)
10-08-2012 03:59 PM in reply to: bobbie.k
Hi
Create the base sketch with req OD of 25mm with 2 points top and bottom.
Created a point for a workplane @ 20mm radius.
Created the workplane at above point.
Create sketch on workplane, create 2 points, left and right.
Create 3D sketch, create a spline between the 4 points, changed the spline fit method to "Minimum energy"
Create the sweep profile sketch.
Sweep the part.
I had a look ad JD methods, all good, just different ways of doing it.
Reg
Message 9 of 11 (151 Views)
10-08-2012 07:53 PM in reply to: rhasell
rhasell wrote:
Hi
The 3D curve is different.
Valued Mentor
rhasell
Message 10 of 11 (145 Views)
10-08-2012 09:11 PM in reply to: JDMather
Thats what I love about Inventor as well as the forums, there is often more than one way to model a part, and when more than one person contributes, that's how we learn (Or at least I have) the different aspects and features of the software.
I did not even consider a 3d intersection, and will store that in the memory banks for future use.
Reg
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
