Inventor Forum
Sweep problem
2 REPLIES 2
foxdj
210 Views, 2 Replies
Sweep problem
I have a problem, when I use sweep it twist around projected curve, and when I use guide face I get self-intersecting error.
when I use helix with less revolutions I get the result but I need more revolutions.
Diameter of profile is not bigger than diameter of helix...
Can anyone tell me where am I doing wrong?
Igor
Tags (1)
2 REPLIES 2
mpatchus
in reply to: foxdj
Take a look at the swept feature and see if this is what you are looking for. If it is, edit the feature an notice the selections made. Hope this works for you.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
foxdj
in reply to: mpatchus
Thank you, this is what I was looking for...
