Inventor Forum
Sweep - Trimming and discarding faces error!!
3 REPLIES 3
LiamHanlon
1054 Views, 3 Replies
Hi all,
I'm trying to sweep six circles along 6 3d sketches however I recieve the 'The attempted operation had problems trimming and discarding faces. Try again with different outputs.
I have been suffering with the above error message and i am at my wits end. I've tried tracing the the geometry, played dot to dot joining up the points but to no avail. Some sweeps work and others dont.
Any help would be greatly appreciated
3 REPLIES 3
CCarreiras
in reply to: LiamHanlon
Hi!
In Sweep tool, if you change to parallel it works!
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
LiamHanlon
in reply to: CCarreiras
Thanks very much Carlos
glenn-chun
Hello OOBean,
Thanks for reporting this issue.  We have logged DID 1506198 in our database.
Glenn
Autodesk, Inc.
Glenn Chun
Sr. Principal Engineer
