Inventor General
Active Member
OOBean
Message 1 of 4 (300 Views)
Sweep - Trimming and discarding faces error!!
300 Views, 3 Replies
09-26-2013 04:29 AM
Hi all,
I'm trying to sweep six circles along 6 3d sketches however I recieve the 'The attempted operation had problems trimming and discarding faces. Try again with different outputs.
I have been suffering with the above error message and i am at my wits end. I've tried tracing the the geometry, played dot to dot joining up the points but to no avail. Some sweeps work and others dont.
Any help would be greatly appreciated
Distinguished Mentor
ccarreiras
Message 2 of 4 (289 Views)
Re: Sweep - Trimming and discarding faces error!!
09-26-2013 05:16 AM in reply to: OOBean
Hi!
In Sweep tool, if you change to parallel it works!
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
Active Member
OOBean
Message 3 of 4 (282 Views)
09-26-2013 05:20 AM in reply to: ccarreiras
Thanks very much Carlos
Employee
GlennChun
Message 4 of 4 (252 Views)
09-26-2013 01:33 PM in reply to: OOBean
Hello OOBean,
Thanks for reporting this issue.  We have logged DID 1506198 in our database.
Glenn
Autodesk T-Splines Component Development
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
