Hey All,
I would need some help with this. Please take a look at the attached file (Inventor 2013). I am trying to do a surface sweep along the 3D path, but I am getting an error: "The attempted operation did not produce a meaningful result".
Why is this, and how do I fix it? The profile is on a sketch that is perpendicular to the end of the path, and the profile is fully constrained. I have successfully done similar sweeps before, and cannot for the life of me understand why it is not working in this case.
Also, there have been situations where I can do a solid sweep but a surface sweep fails. Anyone have experience with this?
Thank you,
Samu
Solved by JDMather. Go to Solution.
The 3D sketch path appears to be of very poor quality and multiple lines rather than a smooth curve.
The 2D profile sketch has un-inspectable, unmanufacturable dimensions.
I would recreate both sketches.
Thanks for your reply JD!
Turns out the 2D profile is ok to sweep, but the problem is with the wonky 3D sketch. You are right, it is not a smooth curve, as it was imported as a 3D polyline created by a 3rd party product. I tried to make it fit/smooth cubic in AutoCAD, but that produced so many vertex points that once in Inventor, the sweep command froze up the program.
My solution, which as a process is tedious but does work, was to create another 3D sketch, and trace the original unusable 3D polyline from vertex to vertex, drawing new line segments. Now I am able to do a surface sweep, one short line segment at a time. I need to keep re-selecting "path" in the sweep command, click on the line, click "path", click on the next line, and so forth.
Is there not a way to select multiple lines? This is better than being unable to produce the sweep at all, but is a very repetitive, slow process... Anybody know? Or, is there anything I can do to the 3D polyline in AutoCAD before importing to Inventor in order to make it sweep safe?
Thanks!
Samu
I guess I just figured out how to avoid clicking on "path" repeatedly... I should be drawing a spline through the vertex points, not lines... Duh!
If you can get a list of points as output from the 3rd party software Inventor will create the path for you.
As far as the profile - sure it would work, but the dimensions are not manufacturable and the sketch is not dimensioned in a way that you would show to any machinist making the product.
I really like your idea about importing the points... Thanks!
Machinist? Your statement would be correct, if the geometry in question was not representing an underground tunnel, Sir 🙂
I ended up closely inspecting the 3D path lines, and there were some tight bundles of short lines along the path. Once I traced over the whole path from start to finish, deleted those tiny anomalies and replaced them with a single line, it works like a charm. I will still look into splines when I get a chance.
Thanks for your help JD, as always. Have a great day!
Samu
