I have also seen this behavior before, IV assumes the closed loop is
the profile and auto-selects it. Should be a switch to turn off that behavior
in the settings.
Bob S.
"darvinv" wrote in message news:40fbbbc3$1_2@newsprd01...
> Same raw deal here, bothh R8 and R9. (RSI) It's an assumption that the
> closed loop is the profile target and the open loop is the path target.
> It's awkward as hell if you've never seen this behavior before. You can
> do it in a slightly different order and save a couple of clicks.
> darvin
> "JDMATHER" wrote in message
> news:29438770.1090236823082.JavaMail.jive@jiveforum2.autodesk.com...
> > I am trying to sweep Sketch2 as a profile along Sketch1 as the path as
> a SURFACE output.
> > It only works for me if:
> > I click on the Surface output Icon
> > Select Sketch1 incorrectly as a path
> > Hold down the Ctrl key and un-select Sketch2
> > Click on the Profile selection icon
> > Click Sketch2
> > Click on Sketch1
> > Ok
> > I am using v8, can someone check this in v9. I should be able to just
> select the profile and path without the extra steps.
> > J.D.
