Inventor General
Active Member
Culdagor
Message 1 of 16 (212 Views)
Surfaces to Solid
212 Views, 15 Replies
01-28-2014 04:34 AM
I know this has been asked many times, but I'm not able to bring these surfaces into a solid. Can someone point me in the right direction? This file was originally imported from a STP file.
*Expert Elite*
Cadmanto
Message 2 of 16 (195 Views)
Re: Surfaces to Solid
01-28-2014 05:04 AM in reply to: Culdagor
Welcome to the forum.
Usually when you can't thicken a surface it means you have surfaces that have intersections that cannot mesh.
What exactly are you experiencing?  What messages?
What version are you running.  Can you post this file here in this thread?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
*Expert Elite*
JDMather
Message 3 of 16 (190 Views)
01-28-2014 05:24 AM in reply to: Culdagor
Right click on the STEP file.
Select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
or
read this
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
Culdagor
Message 4 of 16 (182 Views)
01-28-2014 05:48 AM in reply to: JDMather
Thank you. I'm attaching the step.
Active Member
Culdagor
Message 5 of 16 (180 Views)
01-28-2014 05:51 AM in reply to: Culdagor
Is there a limit to posting attachments? I don't see neither my original .ipt file nor do I see now the .stp file attached to my posts.
*Expert Elite*
JDMather
Message 6 of 16 (177 Views)
01-28-2014 05:52 AM in reply to: Culdagor
Read response #3. - you should be attaching a *.zip, not a *.stp
How large is the zipped file?
What browser are you using to view this forum?
*Expert Elite*
Cadmanto
Message 7 of 16 (174 Views)
01-28-2014 05:55 AM in reply to: Culdagor
I don't either.
Just save it to your local and then browse to where it is under the attachments portion at the bottom of the responding screen.
Best Regards,
Scott McFadden
Active Member
Culdagor
Message 8 of 16 (173 Views)
01-28-2014 05:57 AM in reply to: JDMather
I zipped before I attached I included both the stp and ipt. The zip file is under 4Mb and I'm using Firefox. In case I'm just being obtuse in some way I've setup a D/L link: www.oficio-belico.pt/downloads/dragon.zip
*Expert Elite*
karthur1
Message 9 of 16 (152 Views)
01-28-2014 06:39 AM in reply to: Culdagor
Not saying that its not impossible to get this into a solid, but it will take some work.
*Expert Elite*
JDMather
Message 10 of 16 (124 Views)
01-28-2014 08:32 AM in reply to: Culdagor
Explain what you have tried to get this surface model to a solid.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
