When I'm creating a surface it becomes invisible.
Both lofted and extruded surfaces usually appear as a yellow transparent surface. In my current part the loft or extrusion comes up in the list as greyed out. I've tried the different permutations of visible and translucent and supressing and unsupressing with no success.
It also won't show up in the surfaces folder, in fact there is no folder of surfaces.
I can't include the file.
Solved by JDMather. Go to Solution.
The usual questions -
What version of Inventor?
Service Pack?
Updates?
OS?
Only this particular file?
Persist after reboot?
What does this mean? Can't even post a cropped screen shot of the browser?
@ThomasInventor wrote:
....(editing part in place in assembly).
I can however create surfaces the normal way if I open the part without being in the assembly.
It's 2014 Student edition
Build: 170
Release 2014 RTM Update 2 Edu
Still no files attached. Still no cropped images of browser.
But a tiny bit more information.
I'm going to take a guess that your sketch is at the assembly level rather than the part level.
I am going to guess that you aren't really editing the part in the assembly.
Post screen shot showing browser (while attempting to edit part in assembly).
Hmmmm, I tried every which way and I can't seem to reproduce the behavior you describe.
More information is needed.
If this is student license - why can't you attach files here?
Thanks for bearing with me, here's a screenshot of what it looks like, 2 loft surfaces are greyed out but as you can see they are set to 'visible'.
The white background is in the part, outside of the part the background is grey.
If I have Object Visibility set to not show construction surfaces - I they are as you descibed - set to Visible but grayed out.
But I still can't reproduce exactly what you describe - I think I must be missing something.
Can you reproduce this behavior from scratch in a new experimental assembly?
Thanks!
I checked object visibility and it was unchecked and greyed out in the part, turns out I had disabled it in the assembly.
Ahh, and now I finally figured out the steps to exactly reproduce the behavior.
If I turn off Object Visibility>Construction Surfaces before editing the part in the context of the assembly - I get the behavior you describe. Well now you have it figured out.
I do not see any inconsistency in the behavior - but I can see how it could be confusing to solve (especially with no files!).
Thanks very much, was having the same issue when I was creating a part in the assembly. I couldn't work out why the constructed surface was greyed out in the 'edit' view. Then noticed it was unselected in the assembly view!!
problem fixed.
