I created a simple surface in Inventor LT 2015 but cannot offset the surface.
The command remains disabled (grayed out).
Is this because I use the LT version?
Solved by wim. Go to Solution.
Sorry for late answer.
The thicken/offset command was hidden (for me :-)) behind the combine command, while I was used to find it in the surface menu.
So I added the thicken/offset command to my user commands menu tab and there it remained disable.
Meanwhile I found the right place and all is working fine.
I cannot even reproduce the same thing right now
Thanks for quick reply,
Wim
