You MIGHT try my ReadPointsFromExcel from my IV Tools addin
to create an array of workpoints and then create splines thru the workpoints
and then loft them. I haven't actually tried that myself, but it might work. As an aside,
although the workpoints created will be grounded, they can be changed somewhat
parametrically by manipulating the values in the Excel file and read it back in. The
command will reposition the workpoints according to their names.
Look for the IV Tools addin in the addin section of mcadforums if you don't
have it yet.
wrote in message news:4826263@discussion.autodesk.com...
>I have a set of data that was taken across a surface. This is 21 data point that follow a pattern of outer edge, middle, outer edge
>for 7 lines of z-direction data across a surface.
> I would like to model this data into a surface but this is outside of the realm of how we typically use the software.
> I believe what I want is a surface of M and N nodes with differnet height values. Can IV do this or do I need to go back to MDT?
