Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Suppress occurrence of pattern with iLogic
9 REPLIES 9
Message 1 of 10
fakeru
2317 Views, 9 Replies
Hello!
Is it possible to suppress an occurrence of a pattern in part enviroment using iLogic? I saw something for aseembly enviroment, but I can't make it work for part. My iLogic knowledge is quite basic.
If you have a rule for this, please help me!
Regards
Autodesk Inventor 2015 Certified Professional
9 REPLIES 9
Message 2 of 10
CCarreiras
in reply to: fakeru
Hi!!
I think is not possible because the software can't guess which occurrence to suppress.
Instead, you may create several Patterns, each one with the propper configuration, and use ilogic to supress the Patterns you don't need for each specific case.
Regards
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
CCarreiras
Message 3 of 10
Telson.Hadden
in reply to: CCarreiras
Yes, it is possible.  difficult, but possible - and you have to be careful not to try to change the suppression on the first item, because it will error out without telling you why.
 Dim oPattern As RectangularPatternFeature
 oPattern = ThisDoc.Document.ComponentDefinition.Features.RectangularPatternFeatures.Item("<pattern name>")
 Dim oElement As FeaturePatternElement
 	For Each oElement In oPattern.PatternElements
		if oElement.index = 1 then
			'do nothing - you're not allowed
		else
			oElement.suppressed = True 'or false
		end if
	Next
ThisDoc.Document.update
I know this is an old post, but they are everywhere, with no solution to be found.
Message 4 of 10
serpennica
in reply to: Telson.Hadden
Inventor 2017
I'm working with a "sketch driven pattern" in a part.
Was looking at the script and only got the whole
 pattern to suppress. Was not able to get individual occurrences suppressed.
how do we get the 5, 6,7 occurrence to suppress.
have not seen much on this, mostly with assemblies,
any help, thanks Sergio
Message 5 of 10
Please read your last topic.
And
https://www.cadlinecommunity.co.uk/hc/en-us/articles/210054325-Inventor-2017-quick-tip-Set-rules-to-...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 6 of 10
the option of pattern properties is not what i was looking for.
that option only gives me an if statement to suppress the whole pattern.
I was looking to suppress the occurrences one at a time.
thanks for the help.
Message 7 of 10
DRoam
in reply to: serpennica
This isn't a question of part vs. assembly, it's simply a question of programming. There are many ways to only suppress those occurrences. Probably a Select Case is one of the simpler methods:
For Each oElement As FeaturePatternElement In oPattern.PatternElements
	Select Case oElement.index
		Case 5,6,7
	End Select
Next
Message 8 of 10
DRoam
in reply to: DRoam
Actually, to suppress specific elements, you don't even need to iterate through the elements. You can suppress them directly like this:
Dim oElements As FeaturePatternElements = oPattern.PatternElements
oElements(5).Suppressed = True
oElements(6).Suppressed = True
oElements(7).Suppressed = True
Message 9 of 10
serpennica
in reply to: DRoam
Perfect. That was it.
changed the rectangular pattern to sketch driven pattern and used a function to drive the true/false. now I can get a dialog box "forms" to select the element i want to remove.
thank you.
Message 10 of 10
serpennica
in reply to: DRoam
thank you.
