Inventor Forum
Subtract part
16 REPLIES 16
Message 1 of 17
1048 Views, 16 Replies
Subtract part
Hej to all
I need a big help, I have a part, but i need now is the negative of that
part.
This part have a few channels inside and I need the volume of the channels,
in other words, i need to have in 3d the channels and all the other paths. I
need the empty shapes in my part to became a solid.
How can i do this?
Thanks to all.
sofia
16 REPLIES 16
Message 2 of 17
JDMather
You didn't state what version of Inventor you are using.
You didn't post example file here.
2010 Combine with cut
earlier - Derived Component with Split or Sculpt.
Message 3 of 17
Sorry
I am using IV2010.
I am attachging the file, I need all the inner channels as solids. like the
negative,
than ks
"JDMather" wrote in message news:6275993@discussion.autodesk.com...
Message 4 of 17
> {quote:title=JDMather wrote:}{quote}
JD, her sketches are constrained 🙂
Message 5 of 17
Results of 2010:
1. Extrude a new body over the entire part.
2. Using the new Solid 2 as the Base, Combine - intersect using the
original Solid 1 as the Toolbody.
Result is as shown.
3. Use Delete Face (Lump) to remove any unwanted geometry.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
Message 6 of 17
Wonderful answer, but now cames the next question, how did you made the
solid over the 1 solid?
but that is exactly what I want.
"Dennis Jeffrey" wrote in message
news:6276057@discussion.autodesk.com...
> Results of 2010:
> Result is as shown.
Message 7 of 17
Here's the part.
Message 8 of 17
Thnak you,
But I would love to know how you did that.
news:6276120@discussion.autodesk.com...
> Here's the part.
Message 9 of 17
Sorry, meant CUT, not Intersect. I'll do a video for you...
Message 10 of 17
Thank you thank you, that will be a huge help for the future.
news:6276157@discussion.autodesk.com...
Message 11 of 17
Here's the video...
http://teknigroup.com/Videos/InvDiscussions/Combine1/Combine1.html
Message 12 of 17
JDMather
Most of them anyhow. I think I would have moved Fillet1 below Hole15 instead of adding Sketch25 and Extrusion9.
A work of art, a thing of beauty.
Message 13 of 17
> {quote:title=Guest wrote:}{quote}
> Thnak you,
Roll the "End of Part" marker all the way up to the top of the feature tree. Move it down item/feature by item/feature. Do "Edit Feature" on each on as you go to see what he did.
Message 14 of 17
Thank you for the movie, very good.
How can I save the movie to me? So i can always remember how to do it.
news:6276207@discussion.autodesk.com...
> Here's the video...
Message 15 of 17
Just bookmark it in Internet Explorer or Firefox. A version with sound
will be available in the new courseware I'm releasing in January.
Here's a brief "First Look" at the new courseware:
http://teknigroup.com/training/Inventor/courseware%20preview%20sk-1.html
The courseware consists of text, all color images, videos, and one on
one mentoring by an instructor.
Message 16 of 17
Is this video still available?  I tried accessing it, but it appears to no longer exist.
Thom
Message 17 of 17
JDMather
You should be able to figure it out from the ipt files.
Dennis died about a 15 months ago, not sure what portions of his work might still be avialable.
Attach your file here if you can't figure out your problem.
