Mark the Sub as Adaptive after you get it placed.
Once marked adaptive the DOF's that exist in the sub itself will propagate
to the top level. (if a hydraulic cylinder can be "stroked" in the sub, then
it can be stroked in the top level)
At this point (adaptive subs) the constraints(if you wish to drive the
cylinder, for e.g.) must be applied while working in the context of the top
level.
QBZ
"WaialuaRobotics" wrote in message
news:f13c0ac.-1@WebX.maYIadrTaRb...
> Hello,
> I'm working with Inventor 6 and need some help with placing sub-assemblies
into one assembly.
> I use the "Place Component" method, but when I insert a sub-assembly with
transitional constraints, it still exist on the history, but the constraint
no longer works and it's locked as one piece. Anyone know how to separate
the pieces and allow the constraints to work again?
> Thanks
