Inventor Forum
Style Library Damaged
3 REPLIES 3
243 Views, 3 Replies
I have customized a Style Library for R10... it was created using the 'Style
Management Wizard'. I am now trying to add some revised styles to the
library using 'Save Style to Library' and get this error. I have tries
recreating the library several times with the same result.
Any ideas?
Andrew
3 REPLIES 3
...just to add...
This library works otherwise... for use in new drawings and such.
Andrew,
Please see http://discussion.autodesk.com/thread.jspa?messageID=4816916 for
additional discussion on this topic.
I assume you have renamed a Parts List style with the Styles and Standards
Editor, and then saved the modified back to the style library. This is a
known issue (ID 659643), and the recommended workaround is to use the
"Rename Style" right-click command in the Style Library Manager instead. If
you encountered this message using some other workflow, please post back to
the newsgroup and let us know.
Thank you for your report.
Nathan Los
Autodesk Inventor Framework Team
wrote in message news:4826429@discussion.autodesk.com...
Any ideas?
Andrew
Thanks Nathan... that worked.
Andrew
"Nathan Los (Autodesk)" wrote in message
news:4826520@discussion.autodesk.com...
> Andrew,
> for additional discussion on this topic.
> If you encountered this message using some other workflow, please post
> back to the newsgroup and let us know.
> Nathan Los
> 'Style
> Any ideas?
> Thanks,
> Andrew
