I have always found the render out-put from Presenter 3D to exceed that of
IV-Studio. I thought it was just me.
Dell 670 dual Xeon - 3.2
3gb memory, SCSI320-15k
XP-Pro, sp2
FX3400: Driver: 91.36
IV2008
"MarcoA" wrote in message
news:5566697@discussion.autodesk.com...
il giorno 27/04/2007 14.00 blaque ha scritto:
> I did not, strictly Jpeg, Ill try saving it as BMP. I gotta tell
> ya, the rendering time is long, but the Jpegs are only like 200
> KB.....which is extremely small. Somethings up. SHouldnt render at
> that size, and take that long, and come up with a file that small.
This could confirm my suspect.
The rendering window shows the BMP, if it is ok but the saved image is
not, so the jpeg compression is the guilty.
For quality I always save as BMP (or PNG) and then convert to JPEG
using an image editor (such as TheGimp, that make you choose the
compression ratio and preview its effects and the related file size),
even since Inventor tells us nothing about the used JPEG compression
ratio.
M.
