Inventor Forum
Studio Reflective Gp shows cut reflection
17 REPLIES 17
Message 1 of 18
mf1362
951 Views, 17 Replies
I have a problem with Inventor 11 Studio. The reflection on the ground made by "XZ Reflective Gp" works in a way that when rendered, it shows a partial or cut reflection of my assembly, see attached .jpg file. I have not found yet where this "reflection depth" is regulated. Please help! -Marco
17 REPLIES 17
Message 2 of 18
in reply to: mf1362
In studio, go to Scene Styles, select your scene, then on the Environment tab, select the Ground Plane direction and offset.
-barrett
Message 3 of 18
mf1362
in reply to: mf1362
I tried that before, but as you can see in the attached .jpeg file, the problem is not the degree of reflection or the distance of the plane to the base of the object, the problem is the reflection is not shown entirely on the rendering, it is cut across the bottom of it. -Marco
Message 4 of 18
mf1362
in reply to: mf1362
...and this is also happening to the shadow, as you can see. -Marco
Message 5 of 18
R.Corriveau
in reply to: mf1362
Hi Marco,
Could you post the part?
Message 6 of 18
in reply to: mf1362
Does this behavior manifest in all renderings or only of this part?
Have you tried rendering using any of the other reflective planes? Do they
clip too?
When you click on the render button, does the plane appear to be full-sized?
Message 7 of 18
in reply to: mf1362
How big is the part?
Do your results vary if you zoom out on the part? Can you get "more"
reflection/shadow to render?
Message 8 of 18
mf1362
in reply to: mf1362
a .jpeg is posted, couldn't post a 3d file (?) -Marco
Message 9 of 18
mf1362
in reply to: mf1362
It happens only on this part so far, but I only have a couple of days experience with Inventor studio, so I have done about 6 parts so far
Message 10 of 18
mf1362
in reply to: mf1362
Results don't vary when zooming in or out, the plane looks complete before rendering
Message 11 of 18
in reply to: mf1362
can you post a pic of the screen before you render?
Message 12 of 18
in reply to: mf1362
Marco,
Could you try inserting an extruded rectangle into the scene, assign it
a highly reflective surface style, and place it beneath your assembly?
This may be an issue with how big your assembly is in relation to the
Inventor universe. The shadow/reflection plane isn't infinite, but it
is very, very big.
I wouldn't expect to see this phenomenon unless the assembly were huge.
Thank you,
-Randy
Message 13 of 18
mf1362
in reply to: mf1362
see attached pic before rendering -Marco
Message 14 of 18
mf1362
in reply to: mf1362
Well, I did a new rendering with an extruded 12" rectangle, and the shadow & reflection look good. But when I removed the bar it came back to the same cut reflection. (weird). see attched files
-Marco
Message 15 of 18
mf1362
in reply to: mf1362
Here's the other pic
Message 16 of 18
in reply to: mf1362
It looks like the shadow/reflection plane is, in part, defined by the
extents of the scene geometry. Try placing any renderable geometry out
of the camera view but a good distance away from your assembly.
-Randy
Message 17 of 18
R.Corriveau
in reply to: mf1362
Couldn't or can't?
If you can then roll up the EOP, Zip and post.
Message 18 of 18
DanielLongo
I had the same issue and knew it must have had something to do with the size of the assembly. Mine was a full-size combined cycle power facility that I was rendering to an existing site image. It was just big enough that when offset to a side of the background image that the shaddows would be clipped.I will try creating a derived assembly at half-size for the scene.
