Inventor General
Distinguished Contributor
Message 11 of 18 (125 Views)
Re: Studio Reflective Gp shows cut reflection
07-26-2006 02:04 PM in reply to: mf1362
can you post a pic of the screen before you render?
*Randy Kreitzman (Autodesk)
Message 12 of 18 (125 Views)
07-26-2006 02:46 PM in reply to: mf1362
Marco,
Could you try inserting an extruded rectangle into the scene, assign it
a highly reflective surface style, and place it beneath your assembly?
This may be an issue with how big your assembly is in relation to the
Inventor universe. The shadow/reflection plane isn't infinite, but it
is very, very big.
I wouldn't expect to see this phenomenon unless the assembly were huge.
Thank you,
-Randy
mf1362 wrote:
> Results don't vary when zooming in or out, the plane looks complete before rendering
Message 13 of 18 (125 Views)
07-26-2006 03:43 PM in reply to: mf1362
see attached pic before rendering -Marco
Message 14 of 18 (125 Views)
07-26-2006 03:52 PM in reply to: mf1362
Well, I did a new rendering with an extruded 12" rectangle, and the shadow & reflection look good. But when I removed the bar it came back to the same cut reflection. (weird). see attched files
-Marco
Message 15 of 18 (125 Views)
07-26-2006 03:53 PM in reply to: mf1362
Here's the other pic
Message 16 of 18 (125 Views)
07-26-2006 04:04 PM in reply to: mf1362
It looks like the shadow/reflection plane is, in part, defined by the
extents of the scene geometry. Try placing any renderable geometry out
of the camera view but a good distance away from your assembly.
-Randy
Message 17 of 18 (125 Views)
07-27-2006 07:44 AM in reply to: mf1362
Couldn't or can't?
If you can then roll up the EOP, Zip and post.
Active Member
Message 18 of 18 (81 Views)
01-03-2013 05:51 AM in reply to: *Randy Kreitzman (Autodesk)
I had the same issue and knew it must have had something to do with the size of the assembly. Mine was a full-size combined cycle power facility that I was rendering to an existing site image. It was just big enough that when offset to a side of the background image that the shaddows would be clipped.I will try creating a derived assembly at half-size for the scene.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
