Inventor General
Member
Message 1 of 6 (168 Views)
Accepted Solution
Stuck in imperial
168 Views, 5 Replies
11-29-2012 10:57 AM
Bare with me i am new to inventor and i am studing at college. I dont know how but i seem to stuck in imperial. Every time i start a new drawing i have to go tools>document settings>units and change to metric. is there anyway i can make this change permanent? Any help would be appreciated.
Member
Message 2 of 6 (166 Views)
Re: Stuck in imperial
11-29-2012 10:59 AM in reply to: rmfabrications
I forgot to add i am using Inventor 2010
*Expert Elite*
Message 3 of 6 (160 Views)
11-29-2012 11:05 AM in reply to: rmfabrications
Find the Templates folder and replace the Standard.ipt file with the Standard(mm).ipt file and rename it as Standard.ipt
You will probably want to do this for the assembly, drawing and ipn templates as well.
(in later versions (and maybe 2010) you can Save Copy As Template to replace the standard template.)
BTW - when you installed the software there was an option at that time to set your Standard units.  Later versions made it easier to change after installation.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Expert Elite*
Cadmanto
Message 4 of 6 (155 Views)
11-29-2012 11:10 AM in reply to: rmfabrications
Another thing you are going to want to do is if you create your own templates (as you should to secure these settings)
the folder you place them in needs to be pathed inside of your master project file.
The other thing you should look into is change settings inside of the styles editor possibly creating new styles if necessary.
There are videos on youtube that may help you in doing this.
Good luck.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
*Pro
jletcher
Message 5 of 6 (143 Views)
11-29-2012 11:47 AM in reply to: JDMather
JD if I read this right he is needing this for drawings not part.
So he will need to set up an IDW template and styles and then save back to templates. and save styles.. This way the default style would be mm.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Member
Message 6 of 6 (136 Views)
11-29-2012 11:50 AM in reply to: jletcher
Sorry my wording is poor. i was refering to the part. well to be honest i was refering to everything i made a boo boo when i installed the software in would seem. i have now resolved the issue thanks for all your help
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
