Inventor General
Talayoe
Message 1 of 3 (342 Views)
Stub Tooth Gear Designation
342 Views, 2 Replies
10-20-2012 09:08 AM
Hello all,
Inside of assembly/spur gear generator, is it possible to specify (not seeing it) a stub tooth gear? I have a component here that I need to draw as a stub, if possible.
tks!
-Randy
Inventor 2014 PDS
Valued Mentor
Valued Mentor
wh
Message 2 of 3 (333 Views)
Betreff: Stub Tooth Gear Designation
10-20-2012 01:08 PM in reply to: Talayoe
If I'm understandig right here from Germany, a stub tooth gear has shorter teeth than normal gears.
I think, you can generate a normal gear, and then just do a cut extrusion for the outside diameter.
Walter
Talayoe
Message 3 of 3 (297 Views)
10-22-2012 05:45 AM in reply to: wh
Hi Walter,
Sorry for taking so long to reply, had a busy weekend.
You are basically correct in what I am trying to achieve. What I have (now that I have time to detail it out!) is essentially a 6/12dp, 20pa external GEAR (not spline)...as such making it a stub tooth. I had a look thru the spline designs and they are all 30 deg. pa or more which wont work for me, it just doesnt roll properly with that cutter (we have on the shelf).
I would think having the gearing generator around for a few years now, there would either be an option for the whole depth of a gear (to break away from standard like in this case) or a 'checkbox' or something to select stub tooth and bring you to have more options. Obviously this is just my opinion, but we do alot of stub toothed gearing and this would be very handy! (Just happens to be the first one I have tried to redraw with Inventor).
Thanks for the input! :smileyhappy:
-Randy
Inventor 2014 PDS
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
