Hello all,
Inside of assembly/spur gear generator, is it possible to specify (not seeing it) a stub tooth gear? I have a component here that I need to draw as a stub, if possible.
tks!
If I'm understandig right here from Germany, a stub tooth gear has shorter teeth than normal gears.
I think, you can generate a normal gear, and then just do a cut extrusion for the outside diameter.
Walter
Walter Holzwarth
Hi Walter,
Sorry for taking so long to reply, had a busy weekend.
You are basically correct in what I am trying to achieve. What I have (now that I have time to detail it out!) is essentially a 6/12dp, 20pa external GEAR (not spline)...as such making it a stub tooth. I had a look thru the spline designs and they are all 30 deg. pa or more which wont work for me, it just doesnt roll properly with that cutter (we have on the shelf).
I would think having the gearing generator around for a few years now, there would either be an option for the whole depth of a gear (to break away from standard like in this case) or a 'checkbox' or something to select stub tooth and bring you to have more options. Obviously this is just my opinion, but we do alot of stub toothed gearing and this would be very handy! (Just happens to be the first one I have tried to redraw with Inventor).
Thanks for the input! 🙂
