I have an assembly composed of parts, sub assemblies, and a Frame Generator assembly. For some reason, I am unable to create a structured Parts List in the .idw. The 'Level' pull-down in the Parts List Dialog Box is not availbe for me to select 'All Levels'. I am only able to create a Parts List that is an unstructured list of the individual parts of all the subassemblies. Any ideas on how to correct?
Solved by RogerTheShrubber. Go to Solution.
http://beinginventive.typepad.com/being-inventive/2011/05/exporting-all-level-bom-from-inventor.html
The 'Manage' panel is missing from my 'Assemble' tab and is not available by right clicking on the ribbon.
https://www.dropbox.com/s/5ha8pimnyxre2ic/Screenshot%202014-04-15%2014.44.50.png
Thanks James. I recently upgraded to 2014 and it's seems the 'Manage(BOM)' panel has moved to the 'Manage' tab, so you were right! I was looking for it under the 'Assemble' tab as I was used to and as help files were directing me.
So I have followed the process as described in mcgyvr's post to no avail. The Level pull-down menu is not available for me to select 'All Levels' as has been my past experience.
I just added it to my quick access toolbar.
Thanks for the UI customization ideas.
But to my original issue...I created a new .iam composed of 2 subassamblies, enabled the structured BOM in the .iam file, changed Structure Property to 'All Levels' and I am still unable to create a structured Parts List in an .idw. Any ideas before I reload the software?
Thanks to all for your help.
Not having the pull-downs available to me when generating the Parts List was unusual in my experience. It turns out that I was generating a structured Parts List all along. I was confused because my Frame Assembly BOM Structure was inexplicably set to Phantom leading me to believe, an first glance, that I was not creating a structured Parts List.
