Inventor Forum
Stress analysis of thread connection
1 REPLY 1
Barvas11
1292 Views, 1 Reply
Hi Guys,
Does inventor take into account threads? I want to do a pull test on BSP thread connection but the surfaces between the threads are shown as "bonded" so I gues that the stress analysis will treat it as one part glued together.
1 REPLY 1
CCarreiras
in reply to: Barvas11
Hi!
Your  thoughts are true.
If you want to do a FEA test for this case, you have to model the thread and the bolts as they are in real world.
The Inventor thread is just a image representation, the inventor will look at that as some kind of  weld elements.
Did you find this reply helpful ? If so, use the Mark Solutions!Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
