HI
Is it possible to calculate the deflection a steel block will get, just form it one weight
Just use standard steel material, it is only supported at the end.
Regards
Henrik
Solved by blair. Go to Solution.
Solved by Jon.Dean. Go to Solution.
Yes, it is possible. I assume you want to place the Weight positioned along the bar at a set distance.
You can do this by splitting the face with either a circle or rectangle and placing your force there.
I have attached an example. Hopefully I have understood your question.
Jon.
Remember to add the directionof gravity to your analysis (if applicable).
HI
Hi
Thank for reply, i do understand the estimated setup and way to get a bending result
The gravity vector where shout it be placed in this example
Another question regarding the use of split tool, what dose I do to the surface, is it only
marking a round spot and not removing anything.
Regards
Henrik
The Gravity Vector is just that, the direction/vector that gravity will affect the model in question. It doesn't matter which object/edge you select. If an edge is not in the correct direction, you can expand the box and enter a vector using the XZY boxes.
You need to create a sketch on the desired surface and then create a closed loop then exit the sketch. Select the Split Tool command, then the sketch (closed profile) and finally the surface in question.
If you wish to apply a load to a given spot/area on a surface, you would be required to use the Split Surface to create a separate surface in which to apply either the force/load or support constrain. Otherwise Inventor will apply the load/constrain to the whole surface face.
