Hi all,
I would like to know is there any other autodesk product that does stress analysis like buckling, static, non-linear. etc Other than Inventor. Something deeper except for Autodesk RAS.... Like sesam Genie?
Solved by swalton. Go to Solution.
Here is the range of Autodesk Simulation products:
http://usa.autodesk.com/simulation-software/
I would take a look at:
Autodesk Simulation Mechanical
Steve Walton
If your not bothered about using Autodesk, maybe Femap or something else with the Nastran solver. I did a lot of work creating workflows for surface modelling in Inventor and exporting the geometry to both femap and genie. Femap liked to import split dxf wireframes and genie was good with straight inventor surfaces but didnt like double curvature such as some lofts or sweeps...
What are you trying to do with it? see what others in your industry are using
